In Path of Exile 2, chaos damage builds have taken on a new and terrifying shape thanks to the synergy between the Murkshaft unique weapon and the Bursting Fen Toad skill. While chaos builds have traditionally leaned into
POE2 Currency damage-over-time effects like Poison, Blight, or Contagion, this new combo introduces an explosive, active-cast approach that delivers heavy burst damage with strategic control.
Whether you’re building around traps, totems, or direct casting, combining the Murkshaft and Bursting Fen Toad opens up an incredibly versatile toolkit for both leveling and endgame content. This guide breaks down everything you need to know: what each component does, why they work so well together, and how to build around them for maximum devastation.
What Is the Murkshaft?
Murkshaft is a chaos-themed unique bow introduced in Path of Exile 2 that enhances minion and spell-based interactions with chaos projectiles. While it may appear to be a weapon designed for summoners at first glance, its real power lies in its chaos projectile support, which works in tandem with specialized chaos-based skills like Bursting Fen Toad.
Key features of the Murkshaft include:
+% to Chaos Damage
Projectiles deal additional chaos damage over time
Minions and totems using socketed skills can poison
Chance for projectiles to explode on impact, spreading poison
It comes with 4-6 sockets, often built for bow-casting chaos builds. Most importantly, it modifies how chaos-based projectiles behave, giving them added AoE and DoT (damage over time) capabilities.
Bursting Fen Toad Skill Overview
Bursting Fen Toad is a chaos-aligned minion projectile skill where players summon swampy, plague-infested toads that leap toward enemies and explode in a burst of chaos sludge. These summoned creatures are not traditional minions like Zombies or Spectres—they function more like living projectiles with AI-based pathing and homing.
Core mechanics include:
Summons 1–3 toads per cast
Toads leap toward enemies and explode on impact
Explosion deals AoE chaos damage
Leaves behind a toxic puddle (chaos DoT) for 3–5 seconds
Scales with minion, chaos, and spell tags
The unique mechanic here is that the toads themselves are the projectile, meaning anything that scales projectile or AoE behavior—including supports—applies to them. That’s where the Murkshaft bow comes in.
Why the Combo Works So Well
The synergy between Murkshaft and Bursting Fen Toad is rooted in two critical systems: chaos projectile scaling and explosion modifiers. Here’s how they create a deadly loop of destruction:
1. Toads Count as Projectiles
Because the toads function like projectiles, Murkshaft’s projectile-enhancing chaos mods apply to them fully. This means:
Increased damage over time
Higher AoE on impact
Chance to poison and spread chaos effects
2. Chaos DoT Scaling
Each toad explosion leaves behind a toxic puddle that stacks with other puddles, meaning repeated casts can cover an entire room in chaos DoT zones. With Murkshaft boosting chaos duration, enemies get trapped in a swamp of suffering.
3. Minion + Spell + Chaos Tags
Bursting Fen Toad benefits from a wide array of support gems:
Minion Damage
Void Manipulation
Efficacy
Chaos Penetration
Multiple Projectiles
Minion Speed (toads jump faster and farther)
And with Murkshaft increasing the potency of chaos projectile skills, each leap becomes a nuclear detonation of poison and decay.
Building Around the Combo
To take full advantage of Murkshaft + Bursting Fen Toad, you need to build in one of three ways:
1. Chaos Minion Caster (Occultist or Necromancer)
Focuses on minion and chaos DoT nodes
Uses Profane Bloom for chain explosions
Great for mapping and mob clear
Passive tree investment in Minion Life, Minion AoE, Chaos Penetration
2. Projectile Trap Build (Saboteur)
Converts the skill to traps via Trap Support
Deploys toads as chaos bombs
Focus on trap throwing speed, trigger radius, and DoT
Murkshaft supports scaling of the toad’s projectile explosions
3. Bowcaster Hybrid (Pathfinder or Trickster)
Utilizes cast-on-bow mechanics with high damage
Emphasizes chaos DoT, duration, and projectile speed
Takes Master Toxicist or Harness the Void
Best for players looking to scale Poison, Virulence, or Poison Proliferation
Supporting Skills & Auras
To boost your effectiveness, pair the combo with the following:
Malevolence – Increases DoT duration and damage
Despair – Reduces enemy chaos resistance
Wither Totem/Spell Totem + Wither – 90%+ more chaos damage over time
Plague Bearer – Passive AoE rot for additional chaos clear
Void Sphere – Crowd control for grouping enemies into toad blasts
Ascendancy Synergies
Ascendancy Key Benefits
Occultist Profane Bloom explosions, Wither stacks, Malediction
Trickster Chaos DoT, energy shield regen, mobility
Pathfinder Flask synergy, poison duration, chaos scaling
Necromancer Minion scaling and offering buffs
Pros and Cons
Pros:
High burst damage and AoE
Great synergy with both minion and chaos passives
Strong for both clearing and bossing
Flexible support gem setup (spell, chaos, projectile, minion)
Cons:
Requires specific gear (Murkshaft)
Toad AI can occasionally misfire or delay
Scaling may require investment in both minion and chaos nodes
Vulnerable to chaos-immune or highly mobile bosses without puddle uptime
Final Thoughts
The combination of Murkshaft and Bursting Fen Toad creates one of the most satisfying chaos-based playstyles in Path of Exile 2. Whether you’re coating the battlefield in poison, bursting mobs with exploding plague toads, or scaling massive DoT numbers in boss fights, this setup rewards clever positioning, chaos stacking, and relentless pressure.
If you're a fan of weird, niche mechanics or just love watching enemies melt in bubbling chaos swamps, then this combo is one of the most exciting additions to POE 2 Orbs the chaos damage meta. Get your Murkshaft, train your toads, and let the plague rain down.
MMOEXP-Bursting Fen Toad in PoE 2: Area Control and Trap Mechanics
- paleyShelie
- Postovi: 3
- Pridružen/a: 08. srp 2025, 02:40
- Lokacija: Berat
- Vozim: Nemam auto
- Motor: 1.6 BlueHDI 84KW
