ABS - Anti-lock Braking System
ASC - Automatic Stability Control
ASR(TCS) - Traction Control System
ESP - Electronic Stability Programme
EBA - Emergency Braking Assistance
TPMS - Tyre Pressure Monitoring System
DSC - Dinamic Stability Control
EBD - Electronic Brake Distribution
AC - Air Conditioning
DME - Digital Motor Electronic
EGR - Exhaust Gas Recirculation
K-Jetronic - Continuous mechanical F/I system (K glava)
L-Jetronic - Intermittent electronic F/I system with air flow measuring (protokomer)
SRS - Supplemental Restraint System
ECU - Electronic Control Unit
MAP - Manifold Absolute Pressure
EFI - Electronic fuel injection
TPS - Throttle Position Switch(Sensor)- Senzor pozicije klapne
NOS - Nitrous Oxidion Sistem
ATF - Automatic Transmition Fluid
TB - Throttle Body
WG - Waste Gate
AMM - Air Mass Meter
LPG - Liquid Propane Gas (je l' tako?)
LSD - Limited slip differential
IAC - ventil za dinamicku regulaciju lera (ne znam tacno sta znaci skracenica)
MPI - MultiPoint Injection
PGM-FI - Programmed Fuel Injection
SOHC - Single Over Head Cams (jedna bregasta po glavi)
DOHC - Double Over Head Cams (dupla bregasta po glavi)
VVT-i - Variable Valve Timing Intake
VTEC - Variable Valve Timing Intake and Lift Electronic Control
AB - air bag
AC - klima uredjaj
ECC - elektronsko klima upravljanje
ID - info display
MID - multi info display
TID - triple info display
KAT - katalizator
TC - traction control
TDI - Trubodiesel Direct Injection (VW-ov zasticeni znak) - Turbodizel motor sa direktnim ubrizgavanjem
TDi - isto
TD(crveno)i - isto to, samo sto je crveno I korisceno kao oznaka za 1,9 TDI motor koji je imao 110 ks, dok je osnovni, sa svim sivim TDI slovima imao 90ks
SDI - Saugdiesel Direct Injection (takodje VW-ov zasticeni znak) - Atmosferski dizel motor sa direktnim ubrizgavanjem
VTec - Variable valve Timing and lift Electronic Control, variabilno vreme ventila, ovu skracenicu koristi Honda, BMW ima slican sistem koji se zove VANOS, Toyota ga zove VVT-i, imaju ga Mercedes i Porsche...
HDI - Pezoova oznaka za Common Rail dizel motore
CDI - Mercedesova oznaka za Common Rail dizel motore
GSI - Mislim da konkretno ne znaci nista, inace je koriscena u OPEL-u kao oznaka za snaznije modele (KAddett, Corsa i Vectra, pre toga Manta....)
GTD - Turbo Dizel oznaka za VW-ove motore pre uvodjenja TDI tehnologije, bila je na Golfovima mK1 1.5TD i Golfovima mK2 1.6TD, Golfovima mK3 1.9TD
BPV= by pass valve
BOV= blow-off valve
WI= water injection
CAI= cold air intake
RAI= ram air intake
IAT= intake air temperature
EGT= exhaust gases temperature
IC= intercooler
A/A IC= air to air intercooler
W/I IC= water to air intercooler
Torsen= tor(que) sen(sitive) differential
TC= traction control
BBK= big brake kit
GTI= Gran Turismo Internazionale (stara italijanska oznaka)
BSFC= brake specific fuel consumption
AT= automatic transmission
MT= manual transmission
ASC= active stability control
ECU= electronic control unit
TCU= transmission control unit
HID= ksenon, high intensity discharge
Oznake u auto industriji
