WIP NAV (RNEG) software 50.03b
saban071
Postovi: 11
Pridružen/a: 22. stu 2016, 14:52
Lokacija: Nowhere
Vozim: 30008
Post Postao/la saban071 »
First of all be prepared:
You need time: at least 30 mins for the update process from when it starts to update.
Engine Running: You MUST leave the car running - ignition on is not enough as if the car goes into economy mode it may leave the unit in an inoperable condition.
You will need a blank SD card: A SDHC Class 10 (4 or 8 Gb Minimum) will be fine - but nothing too fast and fancy as you don't want compatibility issues.
Don't use your Navigation SD card to perform the firmware updates! Some later map updates are protected in such a way that prevent the files from working if they are moved from the SD card and copied back later. SD Cards are cheap these days, don't be tight!
You will need an unzipping / archiving programme that works with RAR files: - I recommend the Open Source '7Zip' software from here:
7 Zip Org. 7-Zip is free to use and is a great utility. Select the right version for your system, download and install.
1. Put the SD card into your PC. When the PC recognises the SD card it will assign a drive letter. Right Click the Drive letter and choose 'Format'. Make sure you select the FAT32 File System. Make a note of the Drive letter assigned to the SD Card.
2. Create a new folder on your PC (not the SD Card) and copy the relevant firmware file into the new folder you just made.
3. Right Click on the firmware archive. There should be a 7-zip menu, next click '7-Zip' and another menu will drop out (see picture). Choose 'Extract Files'
4. In the next box, choose the Letter assigned to the SD card earlier, or browse and select the drive letter. Then choose OK.
5. When complete, there will be a file called 'HBUPDATE.DEF' and a folder called 'HEADUNIT' with a lot of folders and files inside. There shouldn't be anything else in the root of the SD card.
6. Next go to the car, insert the SD card and start the car.
7. The system should detect the firmware update and ask you if you want to proceed.
8. Follow the instructions and do not fiddle with the buttons or the Head Unit whilst the update is in progress, unless responding to instructions.
9. If all is successful the unit may restart and you should have the new firmware installed.
Link na firmware: http://s000.tinyupload.com/index.php?fi ... 9250610596
DmrPhilip
Postovi: 135
Lokacija: Ljubljana
Vozim: SW
Ima zahvala: 72 puta
 pohvaljen: 56 puta
Re: WIP NAV (RNEG) software 50.03b
Post Postao/la DmrPhilip »
moj pug nema sd card , ima li koja varijanta da na cd spržim i na taj nacin napravim upgrade !?
Postovi: 2528
Ima zahvala: 171 put
 pohvaljen: 321 put
Onda kod tebe nije ova navigacija.
